Nous sommes actuellement le Lun 27 Juil 2026, 5:00 pm
Ceux qui on Mitchell
Dubreu
MessageMer 09 Mars 2005, 10:49 am
Salut, j'aurais besoin davoir l'image et la description pour démancher le stering et la clef d'iginiton pour un Cherooker Wagoner 1988. Merci!
MetroGSI
MessageMer 09 Mars 2005, 11:30 am
présentement mon mitchell est chié, trop de user loggué en même temps... Mets que ca débloque, je te trouve ca ;-)
Accent 03 up and operational
Swift 94 1.6L à vendre
Sidekick 90 1.3L vendu
Metro 93 1.3L Vendu
Swift GT 90 scrap
Cavalier 92 3.1L scrap
Camaro 80 350ci scrap
Corolla 87 1.6L scrap
Topaz 89 2.3L scrap
Corolla 83 1.6L scrap
Spirit 81 258ci scrap
MetroGSI
MessageMer 09 Mars 2005, 11:55 am
Ignition switch & lock cylinder
The ignition switch and lock cylinder is typically mounted on the steering column and actuated by an ignition key.
Servicing
To gain access to ignition components on Jeep vehicles, the steering column must be removed or lowered and the turn signal switch must be removed.
CAUTION: The lock plate is held by high spring pressure. Do not remove snap ring without using a compressor tool. If the steering shaft has standard threads, use compressor tool (J-23653); if the shaft has metric threads, use Metric forcing screw (J-23653-4).
(Probabalement qu'autre chose peut faire la job, que les outils spéciaux... faudrait je voye ce que ca a l'air)
CAUTION: Special care must be taken to avoid bumping, jolting or hammering on the steering shaft and gearshift tube.
Removal & Installation
Lock Cylinder
Removal
Turn lock cylinder clockwise 2 detent positions beyond ''OFF-LOCK'' position. Compress lock cylinder retaining tab using a thin blade screwdriver and remove lock cylinder.
Installation
Insert key in lock. Hold cylinder sleeve, and turn key clockwise until key stops. Insert cylinder lock into bore with cylinder tab aligned with keyway in housing. Push cylinder in until it bottoms. Rotate cylinder counterclockwise to engage lock sector, and push in until cylinder tab engages in housing groove.
Ignition switch
Removal
Lower column and remove switch mounting screws. Disconnect harness connector. Remove switch
Installation
Move switch slider to ''ACC'' position. Move switch slider back 2 clicks to ''OFF-LOCK'' position. Insert remote ro in switch slider, and position switch on column. Do not move slider. Install and tighten screws.
Metro 93 1.3L Vendu
Swift GT 90 scrap
Topaz 89 2.3L scrap
Utilisateur(s) parcourant ce forum : Google [Bot] and 24 invités
