Nous sommes actuellement le Mer 04 Mars 2026, 10:23 pm
pcv flip hose
pcv flip hose
MessageMar 15 Jan 2008, 8:12 am
quelquun a t il déja entendu parler de ca ? j ai vu ca sur suzuki forum pi j me demande bien quel est l avantage
leur explication
I'll try to explain: Hose routing for our car's PCV does not have the best design for the main Hose Tube ...it's a "Y" rather than a "T" which wouldn't make much difference if were installed more horizontal than vertical but the way it is "stock" ...coming off the main tube is a hose-bib which is meant to supply vacuum from the Intake Manifold ...unfortunately it faces "downward" which is allowing any Oil blow-by in an older motor to drip back into the Intake-manifold causing fouling of Spark Plug in one cylinder & some probable Emmissions problems including early fouling of the Oxygen Sensor and related changes to Air/Fuel Mixture. Flipping this Hose-tube points this Hose-bib "upward" preventing oil from dripping into Intake Manifold (goes back into Valve-cover where it belongs.
la photo
il font cela sur les 3 cyl et 4 soch mais il parle que c'est avantageux sur les gt aussi. votre avis ?
http://i146.photobucket.com/albums/r264/hotrodfeguy/P7250376.jpg?t=1200398965
