Nous sommes actuellement le Mar 28 Juil 2026, 1:43 am
tach
ragez0r
tach
MessageDim 06 Mars 2005, 5:08 am
salut..
excuse mon francais parce que je suis une anglo
bon.. jai une 99 swift (4cyl) avec ignition coil packs.. mais l'auto a venue sans tachometre... alors j'install une.. mais cette kit dits que je doit attacher une fils aux negative du distributeur cap.. mais jai des coil pack.. alors j'imagine que le ECU envoi le meme signal aux instrument cluster pour les tachometre stock..... alors si quelquen save cest le quelle fils.. dit moi svp..
et si vous parler anglais.. meme mieux :D
http://www.cardomain.com/ride/446064
1999 Suzuki Swift
1993 Ford Probe GT [sold] :cry:
MessageDim 06 Mars 2005, 10:43 am
If i remember correctly it`s the Brown/White Wire ! If it`s not this one ! It`s the brown one ! Check on your stock cluster connection you nshould find it !!
And you will have only one of these 2 wire and it will be the good one ! It they dont change after 94 .
MessageDim 06 Mars 2005, 2:25 pm
Welcome on Quebec Swift Club Forum ragez0r...
Don't miss to present yourself and your ride on "presentations" topic.
you can post pictures of your ride, give a clear description of your car and a great one about yourself.
fill your "profile" to know where you're living from.
english & french is accepted here. feel free to use one of them if you like that :)
welcome again and, Have fun !
ragez0r
MessageDim 06 Mars 2005, 7:25 pm
thank you tazzzz, ill do that
glass shadow: k... can i connect it directly to the ecu behind the glovebox ???
thanks again
ill give it a try on the next sunny day
Yes !! But you might check before your cluster plug to be sure it's the good one :P
And maybe take your wire there!
1999 Suzuki Swift
ragez0r
MessageLun 07 Mars 2005, 5:12 pm
Yes !! But you might check before your cluster plug to be sure it's the good one Razz
k.. this is in my post.. but i did not POST that..?!?!?!
what the hell ?
1999 Suzuki Swift
MessageLun 07 Mars 2005, 5:28 pm
Don't be alarmed, people here tend to edit/delete other people posts...
Get used to it!
89ssgti
MessageLun 07 Mars 2005, 6:43 pm
6mon a écrit:Don't be alarmed, people here tend to edit/delete other people posts...
Get used to it!
so true,at least I'm not the only who figured that one out :lol:
MessageLun 07 Mars 2005, 6:52 pm
:cry:
MessageLun 07 Mars 2005, 9:17 pm
always cry about your deleted or locked posts will give you nuthin buddy.. try to find WHO and WHY and arrange that with the concerned person(s). personnaly, i never modded or locked or deleted a post without an advertisement before or an explication by private message.
back to the topic now.
and sorry for those, have been modded or deleted unnecessarily or without a signature by the responsible person.
MessageLun 07 Mars 2005, 9:39 pm
Get used to it!
Yeah, like replacing '¢aliper' by 'caline' and other stupid stuff like that.
Dubreu
MessageLun 07 Mars 2005, 9:41 pm
ché pas si ta remarquer mais on peut pas écrire C-a-l-i-p-e-r ensemble sinon ca donne caliper....étrange... :?: ca c'est une erreur du forum...
MessageLun 07 Mars 2005, 9:43 pm
Rien d'étrange, c'est juste une option de censure du forum PHPBB qui permet de remplacer un mot donné par un autre genre ass par a$$ ou shit par sh!t
Dubreu
MessageLun 07 Mars 2005, 9:45 pm
ahhh...je savais pas qu'il y avait des options dememe...ca sonne logique. Et bien.
ragez0r
MessageMar 08 Mars 2005, 1:35 am
tazz: dont worry, im not accusing you.. im sure someone who has the power to edit other peoples posts did it by accident.. its not as if he made me look bad or anything so its no biggy
can anyone confirm what glass shadow said about the tachometer wire ??? i need to be sure...
thank you
1999 Suzuki Swift
L0G1k
MessageMar 08 Mars 2005, 1:40 am
I can confirm it's the brown wire behind the cluster.
You could always buy a cluster with a RPM froma Swift GT or a 4 cyl and it would fit right in place
Utilisateur(s) parcourant ce forum : Google [Bot] et 1 invité
